1991 Auto Trans Slow Pressure Build Up When Cold
Hello,
I have a recent problem where the trans pressure is not building up immediatly after the car has sat for a while or during a cold start in the morning. When I put it in gear (D or R) immediately after firing the engine it will take 2 or 3 seconds before the car actually is moving. Once running I cannot feel slippage or other anomalies... Does anyone know what causes this and how I can fix it. ...complete trans rebuild? ...external valve rebuild? I still love the ole' CB7 and she gets me to work and back at least three days a week?
check atf level & when is ur last time to do drain & fill?
is atf & the atf level are gd
then check if it give u any code
if not
maybe a dying tranny
if not
Hello Derek,
All fluids are new and at level. No codes are thrown. After the slow initial build up of pressure, the tranny acts and functions normal. After short stops such as shopping or such pressure is instantly there...
jfreakofkorn
Dec 6, 2013 03:39 PM
