EG seats into EK
From: Standing on the corner selling cocaine, rippin shows live on stage for hoes yellin my name
I searched the archives and I could only come up with EG seats will bolt up to an EK, however the passenger side of the EK won't slide forward all the way. Can anyone elaborate more on this, I am confused as too why this will only happen on the passenger side not the driver side. The reason I am asking is there are some S2000 seats for sale that I would like to pick up and they have the EG rails swapped to them. any info provided is appreciated. Thanks
I haven't found any other info, worst case scenario I will have to swap the guts out of my EK seats into them and do the same thing this guy already did for them to fit the EG. There is a thread in the FAQ about the whole process into an EK. I just wanted to know if EG rails bolt up to EKs. That will save me the hassle of pulling the seats apart and doing the necessary modifications to make it 100% functional and safe.
Only reason I can think the seat wont slide is that wire that connects the right side of the seat to the left is loose and has too much slack.
EG rails will only have 3 of the 4 bolts connect to the EK chassis. You should just be able to swap out the one side that doesn't fit.
I guess that pretty much rules out a fast switch in my car. I was hoping they would just bolt in and save me the effort of swapping out the bottom ends of them to make it work perfectly. Thanks for clearing that all up. Having 3 out of 4 bolts lining up makes it just like any other S2000 seat as far as bolting them up are concerned.
