Removing Door Panal, there's a problem. help me....
taking off the door pannels will not mess with anything ralated to the SRS, and you dont need to take off the batery the only thing electic there is the window and locks, but if you want you can alway undo the negative
no man u just take off the screws and pop it off.....a bunch of those damn clips are holding it on.....just took myne off 2 hours ago.
yea i broke a couple of mine the other day and now the panel is a bit loose. those little bastards...gotta go buy more.
I tried to get the panal out today. I couldn't get it out. WHY? This is what I did. (Driver's side panal), I pry both side of the door and the bottom part, popped the clips, unscrewed the plastic screw below the driver's mirror, Unscrewed the little tray holder on the door panal. All loosen up and easy out right? Nope!. No more screws but I couldn't pull the panal out. The only part that was hesistating to come out was the door lock area. Can someone tell me how to get it off? Do I pry out the auto door lock panal too? what about the power windows control buttoms?
Forgot to say, the door lock panel stays on. Just unplug it from behind when you remove the panel.
And when you put the panel back on, make sure the window is lowered. Then lower the front end first to make sure you get the actual plastic of the panel over that metal edge on the door. Then you can slide it forward and lower the rest of the panel onto it. You'll get what I mean when you do it. After doing it once, I can have the panel off in a minute and get it back on in a minute also now.
JasonYo
Jan 24, 2011 02:00 PM
integracura
Dec 17, 2007 02:06 PM
babyviper97
Jan 10, 2003 05:14 AM
