manual tensioner conversion on h22a4
Old Apr 16, 2008 | 02:38 PM
boosted92hatch's Avatar
Default manual tensioner conversion on h22a4
i have a h22a4 and want to use the manual tensioner off a complete h23 i have. do i just use all the parts for the tensioner or do i change the water pump gear and lower crank gear also because i noticed the h23 tensioner whell is bigger than the h22, please, any help is appreciated
Old Apr 16, 2008 | 03:47 PM
98vtec's Avatar
moderator emeritus
Default Re: manual tensioner conversion on h22a4 (boosted92hatch)
you only have to change the water pump, oil pump and timing gear if you use the h23 block.
Old Apr 16, 2008 | 04:08 PM
93PreludeVTEC's Avatar
Default Re: manual tensioner conversion on h22a4 (98vtec)
Im assuming the a4 block is the same as the a on the outside. that being said all you hafta do is change out the tensioner parts. theres a write up on here if you search: https://honda-tech.com/zerothread?id=549516
nemesis25
Nov 15, 2012 04:31 PM
lude of pre 2.3
Feb 15, 2007 07:15 PM
92hondalude
Oct 14, 2004 06:45 PM
prelittlelude
Jan 14, 2004 09:56 PM
Greyout
May 23, 2003 08:01 PM
