HELP! obdo to obd1 harness question
Old Apr 16, 2008 | 01:34 PM
vtec-adykt's Avatar
Default HELP! obdo to obd1 harness question
i ordered a conversion harness to fit a d16z6 in a 91 dx hatchback. everything is fitting fine except for the driver side firewall harness. i have included a pic so you can see my dilemna. the clip on the harness is twice as big and has i think 14 pins. the clip on the chassis has i believe 8 pins. any way has any body encountered a problem like this? and is there a way to wire it all in to make it work?
[IMG][/IMG]
Old Apr 16, 2008 | 03:40 PM
Allday07's Avatar
Default Re: HELP! obdo to obd1 harness question (vtec-adykt)
is the car a stock dx? you ordered a harness made for an si shock tower plug...
Old Apr 17, 2008 | 06:35 AM
vtec-adykt's Avatar
Default Re: HELP! obdo to obd1 harness question (Allday07)
yea its a91 dx. i just pulled a dohc zc engine (obd0) out of it. would that make a difference?
Old Apr 17, 2008 | 08:21 AM
jlicrx's Avatar
someone probably swapped an SI chassis harness into it - the connector on the chassis harness coming out of the firewall is definitely not a DX connector - it is either SI or HF - what about the passenger side? does it connect up o.k. or do you have an extra connector at the firewall with nothing to plug into it?
Old Apr 17, 2008 | 09:30 AM
b16a1eg6's Avatar
Default Re: HELP! obdo to obd1 harness question (jlicrx)
The conv harness looks like its for a MPFI car. You need one for a DPFI car.
Old Apr 17, 2008 | 11:25 AM
thevtecnician's Avatar
Default Re: HELP! obdo to obd1 harness question (b16a1eg6)
Is the plug you're holding in the picture the engine harness or the harness that comes out of the firewall?
Old Apr 17, 2008 | 01:16 PM
vtec-adykt's Avatar
Default Re: HELP! obdo to obd1 harness question (thevtecnician)
the plug i'm holding is the engine harness i ordered. yes the passenger side firewall plugs up fine. its just the driver side.. what are the solutions you guys recommend? is there a way to cut and splice to make it work?
Old Apr 17, 2008 | 06:11 PM
Allday07's Avatar
yea the passenger side will plug right in..the drivers side is the problem..someone had to change the harness to an si
EFinAwesome
May 19, 2012 12:31 PM
Ken99287
15
Jan 7, 2011 03:25 PM
Argetnia
Apr 7, 2005 11:54 PM
ITR981002
Jan 27, 2004 07:48 AM
dwchkypmp20
11
Dec 10, 2003 03:57 PM
