STARTING ISSUE NEED HELP ASAP!!!!
Old Apr 16, 2008 | 12:11 PM
IntegraLS90's Avatar
Default STARTING ISSUE NEED HELP ASAP!!!!
Ok so heres the deal my friends car doesnt start. Its a 92 Integra DB2 GS-R shell with a B20b swap. OBD0 motor with an OBD1 intake manifold, distributor, and O2 sensor, and an LS OBD1 wengine bay harness. it cranks but with no spark. brand new distributor so the ICM is good and it shows power going to the distributor but no spark what so ever. Also all of the fuses are good. He needs the car running by this weekend. is there ANYONE who has had a similar problem or anyone that could help with ideas of what to check? PLEASE!?!?!?!?
Old Apr 16, 2008 | 12:20 PM
northemt88's Avatar
1 what ecu are you running is the dizzy ecu and injectors all obd1?
2 check rotor /cap, spark plugs and wires and the the coil
3 timing- is it spinning at an adequate speed to start normaly?
4 fuses and relays an loose wires or bad wiring that looks suspect?
all i can think of for now, hope it helps
Mikes95eg
Jul 10, 2013 10:55 PM
JDMb18c1HATCH
Jul 3, 2010 07:26 PM
baldeagle432
Sep 29, 2009 03:54 AM
menappi
Sep 21, 2005 03:41 PM
