97 DX, Starting problems
So, my 97 DX has been parked for roughly 3 months, I go outside to start it up the other day & the car refuses to start.. So, I keep the key turned & eventually (50 seconds or so) the engine turns over, but dies shortly after, no matter how much gas I give the car, so I continue trying, hoping that it was just simply a low battery, no dice. I eventually try to jump the car, again no dice. I try a little bit more, before resorting to having my battery tested, & I see black smoke comming from what appears to be the engines starter. None the less, the new battery didn't change a thing, any ideas? TIA
From: CAPITAL CITY Tallahassee D.S., Florida, U.S.A
so the engine's turning over correct? ..if so check for fuel and spark also check your timing... this will help us help you
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Throwdown »</TD></TR><TR><TD CLASS="quote">so the engine's turning over correct? ..if so check for fuel and spark also check your timing... this will help us help you
x2
</TD></TR></TABLE>x2
LyghtFunky1
Jun 28, 2008 03:57 PM
rainmanef
Jan 11, 2005 08:07 PM
