crankshaft question 01 gsr
If i purchase a stock 01 gsr crankshaft will the holddowns come with it or are the holddowns a specific part that only comes on the block??
some 1 please leave sum info because i have a 2001 gsr block that i purchased and i really dnt want to put much money into it it came with 3 of the holdowns in the center missing the only ones that were present were the two ends really dnt wanna make block go 2 waste
The main caps come with the block. See the diagram here:
http://www.acuraoemparts.com/d...ch=no
so is there n e way that i can get sum new caps or will i jus have to get another block that already has come with them installed???
every main cap is pretty much mated w/ the block that they originally came in... you could purchase those that you are missing but u would have to line bore it... to get perfect diameters..
