88-91 Civic suspension & lca on 90-93 teg
Old Apr 16, 2008 | 08:18 AM
vtec8200's Avatar
Default 88-91 Civic suspension & lca on 90-93 teg
Hey!
I`ve done some searching and there isn`t a clear or non-contradicting answer anywhere. So this is for all the future searchers who are wondering.
Will the front and rear lower control arms, shocks and springs from a 88-91 civic fit on a 90-93 integra? Or what do you have to do to make it fit?
This is the info that I have found:
-You need the holes on the LCA for the sway bars
-Civic LCA`s are a little shorter so it will correct camber by a few degrees, if they fit (true?)
-The 88-91 Civic suspension will fit on integra LCA`s if you change de shock fork
-The 88-91 Civic suspension will be lower, especially in the rear (by how much?)
I am wondering this because I`m about to buy a 1992 integra Rs dirt cheap because it has a bent front right lca and the bushings on the rear ones are busted and so are the shocks. I have front LCAs from my 91 civic with polyurethane bushings, kyb agx shocks with H&R sport springs, and am planning to buy blox civic rear lca (I heard it corrects camber by 3 degrees??), If everything bolts up, what a deal for me!
thanks!
Francis
Old Apr 16, 2008 | 04:08 PM
vtec8200's Avatar
Default Re: 88-91 Civic suspension & lca on 90-93 teg (vtec8200)
these are the rear blox civic rear LCAs I want to put on the teg.
budomove
Suspension & Brakes
Feb 5, 2008 08:51 AM
emooheo
Suspension & Brakes
Feb 25, 2007 10:40 AM
andyvaj
Mar 2, 2005 06:55 AM
MrFatBooty
Oct 7, 2002 05:50 PM
