Crx Clutch Question
Old Apr 16, 2008 | 05:53 AM
ChinkyChris's Avatar
Default Crx Clutch Question
hey Guys!
I have done some research and i wanted to verify i was correct before i purchased the clutch!
I have a 91 CRX Si.
D16z6 Engine, 91 CRX Si Transmission. Do I purchase the clutch for the CRX si?
Thanks in advance
Chris
Old Apr 16, 2008 | 06:15 AM
~sp33~'s Avatar
EFB055
You have a 91 CRX Si, and your asking whether or not a 91 CRX Si clutch will fit? Looks like it will.
Old Apr 16, 2008 | 06:20 AM
nomoreavril's Avatar
he has a z6 swap. its not a stupid question, but yes, buy the clutch for the transmission, not the engine. so get the si.
Old Apr 16, 2008 | 07:29 AM
kacivic's Avatar
beg pardon if this is a bit of a noob question, but aren't all d-series clutches basically the same? that is, aren't all d-series transmissions similar enough to use the same clutch?
Old Apr 16, 2008 | 09:13 AM
jlicrx's Avatar
Default Re: (kacivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kacivic &raquo;</TD></TR><TR><TD CLASS="quote">beg pardon if this is a bit of a noob question, but aren't all d-series clutches basically the same? that is, aren't all d-series transmissions similar enough to use the same clutch?</TD></TR></TABLE>all 90-2000 CRX/Civic D-series clutches are the same, however, if you are buying a complete clutch kit, you need to get it for your car year, as the throwout bearings are different
Old Apr 16, 2008 | 03:55 PM
Thanks Guys!!
Old Apr 16, 2008 | 04:34 PM
kellerscobra's Avatar
Default Re: (*****yChris)
I would also count the number of splines on the transmission's input shaft and make sure that the clutch you buy has the same spline count. I've seen 20 and 21 spline clutches advertised as CRX SI clutches.
2003TTacoma
15
Aug 3, 2012 12:34 PM
turbodrabbit
Jan 10, 2010 08:19 AM
vATTACK
Feb 25, 2006 10:50 PM
IYBFL2004turbo
Feb 24, 2005 09:09 PM
civteg1
Sep 29, 2002 10:24 AM
