AC removal but still want to keep the heater working. what needs to go?
1998 integra itr. i want to ditch the AC, but i still need the heater to work. what can i remove so that this is possible? i was thinking the compressor, condenser, and all the AC lines such as high and low pressure. Will this work? do i have to modify any existing lines or reroute any lines? any help is much appreciated as i wanted to get cracking on this on saturday. thanks guys
AFAIK you just have to remove and remove. There will be one hole that's supposed to be filled in with a rubber plug where you take out the condenser. You'll also need to get the plastic box that replaces the condenser. It's easiest to get those parts off whoever you sell your AC to. There might be a few minor firewall plugs, but that should be about it.
thanks jason i will IM you if i have any questions, that cool? also what part are you talking about for the condenser and what line do you cap? read those instructions jason posted and it says nothing about that. from i can see all you do is remove the dryer, lines, condensor, and compressor and its a go. any more help is appreciated. thanks guys
[Modified by gsr98vtec, 1:32 AM 7/12/2002]
nomoreavril
Apr 7, 2009 11:10 AM
gsr98vtec
Jul 13, 2002 12:18 PM
