replacing wheel bearings
Old Apr 15, 2008 | 09:21 PM
tikimonaccrd97's Avatar
Default replacing wheel bearings
So I discovered today that my wheel bearing on the front right side need to be replaced. my car is a 97 accord. Does anyone know how to do it or a link that will help me. do the wheel bearing come separate or with the hub
Old Apr 15, 2008 | 11:10 PM
bseriescrxsi's Avatar
Default Re: replacing wheel bearings (tikimonaccrd97)
it will need to be pressed on and off of the rotor(im almost positive).....most of the stuff you can do yourself but the actual pressing you will need to go to a machine shop
Old Apr 16, 2008 | 04:44 AM
h22a_93accord's Avatar
Default Re: replacing wheel bearings (bseriescrxsi)
yeah just replaced mine on my 93 accord so i think they would be the same. if pop off the tie rod end, the und the bolt going the the fork attached to the a arm, and pop off the ball joint. undo the axle bolt and take the axle out. behind the rotor u will see 4 12 point 10 mm polt undo the and the rotor should come off. then take it to napa. they charged me 5 to press the bearing on but my friends dad owns the place. don't forget to undo the brakes
Jacob Weiser
Nov 24, 2012 10:29 AM
rcgrillo
Sep 8, 2008 04:38 PM
TEAM JDM-P
Aug 13, 2007 03:36 AM
gnar kill
Oct 24, 2006 04:04 PM
93ex2draccord
Nov 30, 2005 11:36 AM
