crank pulley tool size.
Old Apr 15, 2008 | 08:00 PM
CRX_RR's Avatar
Default crank pulley tool size.
for all b-series. R they all the same size? im trying to find the size for an itr..
Modified by CRX_RR at 9:38 PM 4/23/2008
Modified by CRX_RR at 9:42 PM 4/23/2008
Old Apr 16, 2008 | 08:58 PM
ahglaze1's Avatar
Default Re: crank pulley tool size. (CRX_RR)
yep they should be the same on all of them u can buy them at ur closest honda dealership they are worth it very good investment
Old Apr 23, 2008 | 08:41 PM
CRX_RR's Avatar
Default Re: crank pulley tool size. (ahglaze1)
ok i found the size of the tool 50mm.... now i need to know if i take the pulley off. does it by any chance messes around with the timing belt. or is it all hole different part.
Old Apr 23, 2008 | 08:51 PM
zrickety's Avatar
the pulley can be removed without disturbing the timing belt
Old Apr 23, 2008 | 08:53 PM
CRX_RR's Avatar
Default Re: crank pulley tool size. (zrickety)
ok thank you sir.
Old Apr 23, 2008 | 10:12 PM
sanimalp's Avatar
$cat /dev/urandom
The tool is the same for all hondas that can use the tool, as someone said, and you can take it off without disturbing the timing belt. That tool is the best tool i have ever bought.
vince yeah
Apr 23, 2004 12:55 PM
matix
Nov 19, 2003 07:56 AM
matix
Nov 13, 2003 11:49 AM
LOwrestling2001
Jul 16, 2002 10:15 AM
