What size tires with gsr tranny?
Old Jul 11, 2002 | 03:04 PM
blufke's Avatar
Default What size tires with gsr tranny?
for my speedo to be accurate what size tires will i need with the gsr tranny in my 92 vx. stock 13" wheels. the speed is determined by the tranny or the wheels?? what size tires will i need. i kinda want to get some 14" hx wheels w/ falkens.
Old Jul 11, 2002 | 03:14 PM
tinkerbell's Avatar
Default Re: What size tires with gsr tranny? (blufke)
try this:
(had a similar post yesterday...?)
http://miata.net/garage/tirecalc.html
im pretty sure the speedo determines hte speed by the combination of hte tranny and tyre diameter.
with out changing the internals of the tranny, it is hte tyre diameter that determines speedo accuracy...
using the tyre calculator, if stock = 185/70R13 then you need 185/65R14's
does this help?
t..
Old Jul 11, 2002 | 03:23 PM
blufke's Avatar
Default Re: What size tires with gsr tranny? (tinkerbell)
from factory its 165/70r13. and i hadnt noticed but i actually have 155 on there(came on car) so theyre smaller. im wondering then, if i get the 14" hx wheels do i need to get the 165/r14? or because im using the gsr tranny will it be something diff. id like to get the falkens and the hx wheels. what do i do?
Old Jul 11, 2002 | 03:37 PM
tinkerbell's Avatar
on a performance honda 185's should be a minimum.
if the originals are 165/70R13's tehn to keep spedo accuracy teh tire calc suggests 185/55R14's
i dont think the tranny has anything to do with speedo accuracy, ie they are interchangable without effect.
but no-one has agreed or disagreed with me on this!!!!!
t..
Old Jul 11, 2002 | 08:46 PM
blufke's Avatar
how can increase the size without messing up the accuracy?
[Modified by blufke, 7:10 AM 7/12/2002]
Old Jul 11, 2002 | 08:50 PM
tinkerbell's Avatar
OMG!
no!
for example: in a 185/65R13 tyre
the 185 is the width,
the 65 is the profile (a percentage of the width)
R stands for 'radial'
and 13 is the wheel diameter to which the tyre is fitted.
i hope this clears up your confusion...
t..
Old Jul 11, 2002 | 10:04 PM
blufke's Avatar
so the speedo will be off no matter what then right?
Old Jul 11, 2002 | 10:10 PM
blufke's Avatar
195/60R-14 86H B is the smallest falken azenis. and at 63mph itll say im going 60. and what is the width of this tire? my stockies are 5".
civic402lx
Jan 20, 2017 07:50 AM
Apotheosis
Oct 8, 2008 02:45 PM
92civicfreak
Jun 24, 2006 04:46 PM
vboy714
Mar 26, 2005 07:42 AM
lilredhatch
Mar 2, 2004 07:04 PM
