ignition switch on a '97
Old Apr 15, 2008 | 06:25 PM
Bodark's Avatar
Default ignition switch on a '97
Does anyone have any advise on changing out an ignition switch and key cylinder on a '97 LX with an automatic transmission?
Old Apr 15, 2008 | 07:14 PM
hondadude's Avatar
Default Re: ignition switch on a '97 (Bodark)
First remove the lower steering column shroud, then tilt the wheel down and remove the upper shroud.
The electrical part of the switch is held on with 6mm bolts. Then follow the harness down and unplug it.
HEADS UP; be careful of the SRS cable in that area.
The tumbler part of the switch is held on by a collar that has breakaway heads on the bolts. [heads are broken off] I use a small chisel along the outer edge to get them turning back out.
Before you install the new tumbler take it to a locksmith and they can set the tumblers to match your old key. Then you only have one key
Old Apr 15, 2008 | 07:49 PM
TheMuffinMan's Avatar
He knows where you live!
The electrical portion?
The electrical portion is 3 bolts like hondadude said, 2 are easy to get to, the 3rd is a pain in the ***, it's located on the far side of the switch facing the dashboard.
fin781
Apr 23, 2011 01:13 PM
madcrx69
Feb 14, 2011 02:56 AM
jaghouse
Jun 15, 2007 12:28 PM
urbanlegend21
Dec 21, 2005 07:15 AM
