camber kit or not?
Old Apr 15, 2008 | 06:15 PM
bikerbo1's Avatar
Default camber kit or not?
I was wondering if it was possible to just put washers on my stock camber kit that comes on the car to stretch it and even out the camber out or just buy camber kit? is it possible to do that or not?
Old Apr 15, 2008 | 09:40 PM
Da9Gro's Avatar
Default Re: camber kit or not? (bikerbo1)
only on your rears, but you have to get longer bolts
Old Apr 15, 2008 | 09:43 PM
Rediness_code's Avatar
Default Re: camber kit or not? (Da9Gro)
do it right and get a camber kit
Old Apr 16, 2008 | 07:37 AM
LadyDc4's Avatar
Default Re: camber kit or not? (Rediness_code)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rediness_code &raquo;</TD></TR><TR><TD CLASS="quote">do it right and get a camber kit</TD></TR></TABLE>
X2! they are not that expensive its worth it
Old Apr 16, 2008 | 08:04 AM
St. Jimmy's Avatar
* B A N N E D *
Default Re: camber kit or not? (LadyDc4)
Most rear camber kits are just longer bolts and some washers, unless you plan on replacing the whole control arm. You can go buy a camber kit, but its going to be the same thing that you can get at home depot for cheaper.
Old Apr 16, 2008 | 08:53 AM
96cgpteg's Avatar
Default Re: camber kit or not? (St. Jimmy)
Unless your car is dropped more than 2-2.5 inches, you probably dont even really need a rear camber kit. You will have some camber, but will still be within factory spec. You may need one for the front, and in that case i would just have the tech adjust the front camber to around the same degree as the rear.
Old Apr 16, 2008 | 11:42 AM
DiMpL3s.'s Avatar
Default Re: camber kit or not? (96cgpteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96cgpteg &raquo;</TD></TR><TR><TD CLASS="quote">Unless your car is dropped more than 2-2.5 inches, you probably dont even really need a rear camber kit. You will have some camber, but will still be within factory spec. You may need one for the front, and in that case i would just have the tech adjust the front camber to around the same degree as the rear.</TD></TR></TABLE>
X2
kasperxtcy
Suspension & Brakes
Mar 26, 2008 01:59 PM
Rionmann
Suspension & Brakes
Feb 3, 2006 05:48 AM
civiccoupe94
Mar 22, 2005 07:40 AM
i3luemrld
Feb 6, 2004 11:44 AM
E-lude78
11
Oct 20, 2003 07:21 PM
