Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Master Cylinder question
Old Apr 15, 2008 | 05:58 PM
RoadRacer46's Avatar
Default Master Cylinder question
I have a 93 Civic DX.
I replaced the rear drums with DA rear discs.
The stock M/C size is 13/16th. Will that M/C be ok, or
should I switch to the 15/16th unit?
The front calipers are stock.
Also, should I run the 40/40 prop valve?
Thanks in advance for the help!
Old Apr 15, 2008 | 06:24 PM
JW racing's Avatar
Default Re: Master Cylinder question (RoadRacer46)
you should be fine untill you upgrade the fronts, then I would do the 4040 and master cyl.
Old Apr 16, 2008 | 09:09 AM
Evs-One's Avatar
Solbros Owns Me
Default Re: Master Cylinder question (JW racing)
92-95 Civic SI non ABS came with the 13/16ths master cylinder with rear discs.
I upgraded mine to 15/16ths and GSR front brakes and it felt MUCH better
SOKDO
Jul 20, 2013 02:03 PM
skill178
16
Oct 9, 2011 04:38 PM
Audifan28
Aug 5, 2008 10:32 AM
JBLAZE622
Mar 12, 2008 06:33 PM
aznphantoms
Dec 2, 2004 11:43 PM
