JDM b18c into USDM GSR
Old Apr 15, 2008 | 05:31 PM
RA217252's Avatar
Default JDM b18c into USDM GSR
I just want everyone to know, that I searched and searched and couldn't find a correct answer.
I purchased a 97 JDM B18c from HMO. I just recieved the motor. It's going to go into my 1994 GSR this week. And before I do the swap, I wanted to make sure I have everything correct.
Can I use my USDM ECU?
I put my USDM harness onto the JDM b18c correct?
What else am I missing.
Thanks HTers.
Old Apr 15, 2008 | 06:06 PM
RA217252's Avatar
Default Re: JDM b18c into USDM GSR (sheehan024)
ne1?
Old Apr 16, 2008 | 04:50 PM
94VTEC2TONE's Avatar
the ecu i dont think will work cuase your running different compression. would need a chipped ecu i belive
Old Apr 17, 2008 | 09:28 PM
r_Senik's Avatar
Default Re: (94VTEC2TONE)
to be on the safe side use your old dizzy, alt, and maybe intake mani.other than that every should work
Old Apr 20, 2008 | 08:35 AM
JeffBro's Avatar
You could get away with running your usdm ecu. I have a b18c in my EK and I have both a jdm ecu and a usdm ecu and they both run about the same. Its close enough I wouldn't worry about afr. But you could easily chip that ecu and dyno tune it...
Death_to_Thieves
11
Apr 23, 2009 12:10 AM
iNERtIA
Feb 3, 2007 09:00 PM
Hoodwinked
Nov 23, 2004 07:07 PM
wizards581
Oct 17, 2004 08:41 AM
willyboyK20
Mar 11, 2002 03:23 AM
