Spoon monoblock caliper fitment
<U>GOT THEM TO WORK, MUAHAHAHA</U>
Thanks for the help and ideas everyone
Sorry for the shitty pictures, late and dark out.
<U>Previous Post</U>
Anyone here have experience with the MONOBLOCK calipers? Not to be confused with the twinblock design. I'm having trouble getting the fitment correct and wondering if anyone has installed the monoblocks on a dc2 before.
Modified by godnf8 at 9:59 PM 4/17/2008
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Zygspeed »</TD></TR><TR><TD CLASS="quote">What made you think they would fit?
They were meant for an S2K.</TD></TR></TABLE>
Spoon offers a monoblock kit for the DC2
OP: "mooman" has done the conversion before.
Cuz I'm sexy like that, you need a special rotor that was designed for the dc2 application. Has a deeper top hat giving it a different offset.
45251-5h11416 is the part number if you care to search, k thx
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by highroller54 »</TD></TR><TR><TD CLASS="quote">mugen bbk dc2r rotors and spoon monoblocks
I have a mugen bbk for sale if you want
Sent a PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Zygspeed »</TD></TR><TR><TD CLASS="quote">Are you trying to use stock ITR rotors or S2K rotors?
edit -- see above ^</TD></TR></TABLE>
Not sure, guy I bought them from said the rotor's he'd ship with calipers would work
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RagingAngel »</TD></TR><TR><TD CLASS="quote">
OP: "mooman" has done the conversion before.</TD></TR></TABLE>
Got these from the "mooman" aka MooFx
</TD></TR></TABLE>Sent a PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG6-DC2 »</TD></TR><TR><TD CLASS="quote">By that picture, your caliper is on upsidedown. The bleeder valve needs to be facing up.
That was me being creative trying to figure out WTF I have permabrakes
when moofer told me the rotor he was mailing me would work
</TD></TR></TABLE>That was me being creative trying to figure out WTF I have permabrakes
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG6-DC2 »</TD></TR><TR><TD CLASS="quote">What side of the bracket did you put the washers on?</TD></TR></TABLE>
Yeah, PM'd you. Did you ever get married? I thought you were moving to the midwest?
FYI, S2000 rotors cannot be used on this application because they won't fit on the ITR's wide hub.
Also FYI, they can be used if they are redrilled and centering rings are used and washers are used for 4x100 applications of this setup.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrakeExpert »</TD></TR><TR><TD CLASS="quote">FYI, S2000 rotors cannot be used on this application because they won't fit on the ITR's wide hub.
Also FYI, they can be used if they are redrilled and centering rings are used and washers are used for 4x100 applications of this setup.</TD></TR></TABLE>
That is correct. I tried placing stock S2K rotors on my ITR hub before and the hub was too wide for it. I had to use Spoon's 300mm large rotors (shown in pic above), which is the same size as S2K rotors.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MooFX »</TD></TR><TR><TD CLASS="quote">
That is correct. I tried placing stock S2K rotors on my ITR hub before and the hub was too wide for it. I had to use Spoon's 300mm large rotors (shown in pic above), which is the same size as S2K rotors.</TD></TR></TABLE>
I picked up a set of RSX Type S Rotors from autozone today and they are the exact same size, width, diameter, and height as the spoon rotors moofx.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG6-DC2 »</TD></TR><TR><TD CLASS="quote">So does that mean that they are not working right either?</TD></TR></TABLE>
Nope, went to 4 places, noone had the tsx or s2000 rotors. Was going to try them all. I'll get it working this weekend and order 45251-5h11416 rotors to try out to see if these eliminate the need for washers
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yellow blur »</TD></TR><TR><TD CLASS="quote">Bleeder valves should be facing upwards. You should flip the valves around if you get the chance to.
Ed</TD></TR></TABLE>
Yeah, not sure if you saw my previous post. I flipped it around trying to be creative to see if I can fix the spacing issue. I originally had them facing up
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegdude227 »</TD></TR><TR><TD CLASS="quote">thats pretty cool man looks hot im thinking sunday on the rims ?</TD></TR></TABLE>
PM'd, sounds good
PM'd, sounds good
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RagingAngel »</TD></TR><TR><TD CLASS="quote">what did you do to finally get them to work for you?</TD></TR></TABLE>
Used a grade6 steel washer, moofx said he ran a washer as well to correct the offset of the caliper. The spoon rotors ended up being the exact same as RSX type S rotors, I went around and picked up a bunch of rotors to try different fitments. I think the stores were pissed off when I took them all back lol.
