Need brake experts
Old Jul 11, 2002 | 02:11 PM
MRSI00's Avatar
Default Need brake experts
I was trying to park my car on my drive way but after i pull up my e-brake my car still rolls back, I have no problem when i park my car on a flat surface but when i park my car on my drive way which is kind like steep hill, no matter how hard i pull up my e-brake my car still rolls back. I replaced my rear brake pads/rotors and i still have the same problem, could anyone tell me what is going on, I did my e-brake adjustment like a month ago, could it be too tight and cable loss its stength? I took it to the dealer but they say everything works fine, they just dont want to fix it, then i took it to somewhere else, some says its too tight and some says that it cant be adjusted, what should i do?
Old Jul 11, 2002 | 02:15 PM
CHONCH's Avatar
Default Re: Need brake experts (MRSI00)
is there any tension on the cable when you pull it up?
Old Jul 11, 2002 | 02:17 PM
MRSI00's Avatar
yes it does, i can tell by the color of the cable.
Old Jul 11, 2002 | 02:28 PM
civicgsr19's Avatar
Your rear shoes need to be adjusted, assuming this has rear drum brakes, easy fix. Post if you need help.
Old Jul 11, 2002 | 02:29 PM
MRSI00's Avatar
Default Re: Need brake experts (civicgsr19)
I dont have a drum, i have disk because i have a 2000 Si. How can i adjust that?
Old Jul 11, 2002 | 02:42 PM
racecarpete's Avatar
adjust the cable
Old Jul 11, 2002 | 02:49 PM
J T*'s Avatar
Default Re: Need brake experts (SilverCivic2k)
yeah it sounds like you need to tighten up the cables.
pull off the arm rest and start turning that middle nut between the cables.
760PhatBoyz
Suspension & Brakes
Sep 9, 2010 02:43 AM
cinci27
Sep 9, 2007 08:41 AM
Dealer Leaf
Nov 15, 2006 04:20 PM
sleepystyle
Jan 11, 2006 01:15 PM
MRSI00
Jul 11, 2002 02:34 PM
