tranny making whinning, when letting clutch out slow......LS engine
Ok, I got an LS swap into my 95 cx hatch and it doesn't get driven much for other reasons, but anyways, everytime i drive it the tranny makes a whinnin noise kinda when i let the clutch out slow. Even when going from like 2-3rd gear i can hear it whine. Its when i let the clutch out slow it makes the whinning noise.
Is it my throughout bearing??
How much do they cost and where do i get them?
It sounds like your synchros. A bad TB would whine when you let the clutch out not as you are doing it. As you let the clutch out slowly the synchros are trying to syncronize tranny speeds to the speed of the engine.
First thing I would do is change the tranny fluid. My D16 tranny whined a lot when downshifting and going slow in first gear and stuff, and when I drained and re-filled the tranny when I did my CV boots, all the whirring/whining went away, and the shifts are much smoother now. It's worth it to do this first at least, before you start thinking about synchros and throwout bearings. Mine uses 10W-30 or 10W-40 motor oil, I think yours does too, but check in a manual first before you go filling it up with motor oil in case your tranny uses gear oil instead like most manual trannies.
[Modified by matt-eg, 7:15 PM 7/12/2002]
