CEL Light Codes 7 and 16
Old Apr 15, 2008 | 12:49 PM
MoparSteve's Avatar
Default CEL Light Codes 7 and 16
I see that the 7 is a TPS fault and the 16 is the Injector fault.
Anyone know of a place to get the TPS setup? I called my Honda dealer and they said no longer available and id it was they wanted a loan on the house to get it..
The car will Idle high and have a tip in stumble at times but still runs ok... Anyone have a good used one or know of someone who can fix this one?
It is the 1.5l hatchback car..
Old Apr 15, 2008 | 01:00 PM
turbo1.5's Avatar
Did you try resetting the ecu to see if the code comes back? In a '88-'91 dpfi set up even changing the tension on the throttle cable can cause a cod 7. The code 16 is your injectors going out. That code may not return after you reset the ecu. If the problems still persist I will sell you a dpfi throttle body with a new tps and injectors for dirt cheap. Pm if you are interested
Old Apr 15, 2008 | 01:16 PM
MoparSteve's Avatar
Default Re: (turbo1.5)
You have an Instant Message...
Old Apr 15, 2008 | 01:18 PM
turbo1.5's Avatar
Replied
Old Apr 15, 2008 | 01:32 PM
MoparSteve's Avatar
never saw a reply...
could you just email me at turbo6@bellsouth.net
Old Apr 15, 2008 | 01:50 PM
Perfectionist's Avatar
Default Re: CEL Light Codes 7 and 16 (MoparSteve)
Can't help you out with the TPS, but...
Your code 16 is for the injector circuit and is triggered when there is a break in the electrical path. It could be caused by many things. A loose fuse, resistors, clips, main relay, and all the wiring in between. My vote is the main relay. A cracked solder joint opens intermittently and sets the code. Normaly the fuel pump side of the relay opens up causing a no start condition, but the other side powers the injectors.
Old Apr 15, 2008 | 03:55 PM
MoparSteve's Avatar
Default Re: CEL Light Codes 7 and 16 (Perfectionist)
The car has shut off a couple of times.. I wonder if that is what is happening... Also the throttle cable ifeels like it sticks at times.. I wonder if that is causing the TPS problem also..
JohnCBauman
Oct 3, 2011 09:53 PM
d15b7racer
Jan 12, 2005 10:35 AM
jester
Dec 1, 2003 06:29 AM
shadowstylz
May 8, 2003 07:52 PM
