h22 internals in a h23 block, possible?
Old Apr 15, 2008 | 12:47 PM
boosted92hatch's Avatar
Default h22 internals in a h23 block, possible?
hey whats up, i am wondering if anyone can tell me if the internals from a h22 will fit in a h23, i just want to keep the h23 pistons and closed deck. im trying to run a lower compression engine for boost. thanks to anyone with answers
Old Apr 15, 2008 | 12:49 PM
v4lu3s's Avatar
RTFM
it will blow up in second even though the h23 block and h22 bare blocks the same except for the oil squirters being in the h22 and the block stamp being different.
Old Apr 15, 2008 | 01:49 PM
jdmlude5
Guest
Posts: n/a
Default Re: (v4lu3s)
from what i can remember h23 have oil squirters also
Old Apr 15, 2008 | 01:58 PM
v4lu3s's Avatar
RTFM
Default Re: (jdmlude5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmlude5 &raquo;</TD></TR><TR><TD CLASS="quote">from what i can remember h23 have oil squirters also</TD></TR></TABLE>
not according to their parts diagrams.
Old Apr 15, 2008 | 02:09 PM
your right, i have both apart and no squirters in the h23, v4lu3s why do you say it will blow up in seconds
Old Apr 15, 2008 | 02:11 PM
v4lu3s's Avatar
RTFM
because its crazy that you could put h22 or h23 parts into the other engine! the gravitational fields of each part will clash, leading to a rift in the space time continuum leading to massive destruction in the immediate vicinity of the rift!
seriously though, they are the exact same block. Honda stamped them differently to address the different crank, pistons and rods.
Old Apr 15, 2008 | 02:14 PM
Rosko's Avatar
you can always swap the squirters from the 22 into the 23 as well. identical blocks when you tear them all the way down.
h22_crx
May 7, 2007 12:41 PM
non_Vtec4700
Apr 22, 2004 12:15 PM
DRAGLS
Dec 30, 2003 12:46 PM
accorracer
Dec 30, 2002 10:15 PM
