bad idle and code 6
Old Apr 15, 2008 | 12:05 PM
higgunscrx's Avatar
Default bad idle and code 6
every once and a while, my check engine light comes on and the ecu shows code 6 which i know is etc sensor (temp sensor). anyways i've had a bad idle for a while now too, and was reading that the temp sensor could possibly send the wrong info to the ecu and cause a bad idle. does this sound like it could be the problem? the idle just slowly falls at a stop to about 600rpms and then goes back up sometimes. the etc sensor is pretty cheap but i dont want to replace it if i dont have too.
Old Apr 15, 2008 | 12:09 PM
91ed9's Avatar
Default Re: bad idle and code 6 (higgunscrx)
could be the sensor, check the connector if anywires are loose. you said this happens intermittently? maybe a wire before you buy the sensor
what engine is this, n car?
Old Apr 15, 2008 | 12:28 PM
higgunscrx's Avatar
dohc zc
it would be hard to say its a bad connection wouldnt it cuz its itermittent
i checked the connector once last week seemed ok
t_seymour
May 12, 2012 04:12 PM
RiTtEk401
Oct 4, 2011 02:52 AM
Drew Peacock
Jan 22, 2006 10:08 PM
black sohc civic
Oct 30, 2005 07:02 PM
