Fuel injector cleaning? Rip off or need?
Whats your opinions on this? Do you have it done in the shop or do you just pour in a bottle in the gas tank? If so, What type of stuff do you use?
Reason for asking cause I just had a "professional" fuel system cleaning at Jiffy Lube for about 50 bucks. They place a bottle handing off your hood while it takes about 15 minutes to clean with engine running. Drove off the lot and didn't feel much of a difference in power. Discuss.
Modified by 91tegra07 at 8:16 AM 4/15/2008
Use some Seafoam in one of the vacuum lines get a bottle of Lucas to put in the gas. Use the rest of the Seafoam and pour it in with your oil and run it a while before you change your oil. There might be better things out there but these worked great for me and you only spend about 12 bucks
EK45VTi
10
Sep 21, 2004 07:03 PM
