problem with fuel pressure on 92 accord
im having a fuel pressure problem after swapping to an f22b1 in my 92 accord.....if i start the car and let it run it will bog down and sometimes stall but if i put a pair of vice grips on the line coming off the fuel pressure regulator(the big one on the bottom)....my mechanic told me theres definitely a fuel pressure problem and we tried another regulator with the same results....he also said it could be a bad fuel pump but wasn't sure......i would appreciate any input this is a real stumper
There IS a test port on the end of the fuel rail so you can hook up a gauge to check the pressure.
That would tell the tale.
You sure of the FPR vacum line is hooked up correctly?
Skyler June
Feb 21, 2019 11:19 PM
