Tire question...will it fit?
Old Jul 11, 2002 | 12:48 PM
N24RE's Avatar
Default Tire question...will it fit?
will 225 45 15 Hoosiers fit on my stock wheels and not rub?
I am sure someone has tried this. I have an opportunity to get some tires from a local race team, but I don't want to go buy new wheels.
Thanks
Old Jul 11, 2002 | 01:01 PM
Reid's Avatar
Global Moderator
Default Re: Tire question...will it fit? (N24RE)
In the front you'll be fine with H&R 5mm spacers with stock wheel studs.
In the rear you'll need a 5mm spacer which will require extended wheelstuds.
I've run 225/45/15 Hoosiers in the front with 5mm spacers. I have stock suspension.
Old Jul 11, 2002 | 01:02 PM
B18C5's Avatar
I don't think so. Some people fit 225 Kumhos on stock rims in the front only, and that's with the use of spacers. The rear will not fit without at least rolling the lip. 225 Hoosiers are wider than Kumhos, so they probably won't fit. Some people say 205 Hoosiers are about the same width as 225s of other brands.
Even if they fit it would be a very bad idea. The tires will be pinched far too much and will be squirmy. 225 Hoosiers need at least a 7" rim to be comfortable.
Old Jul 11, 2002 | 01:04 PM
N24RE's Avatar
Default Re: Tire question...will it fit? (B18C5)
Gotcha....looks like I'll be needing some wheels....unless I just buy new tires that fit...hmm...what to do
Blanco'03
Honda CR-V & Element
Aug 12, 2015 03:19 AM
hondapeeler
Dec 2, 2010 08:59 AM
crxchris
Jul 29, 2006 01:36 AM
NONKonformyst
Jan 11, 2003 08:08 AM
R-Adrenaline
Nov 5, 2001 04:57 AM
