high idle, early redline WTF
Old Apr 14, 2008 | 06:37 PM
aWeimaraner's Avatar
Default high idle, early redline WTF
Heyo, I returned my lsvtec turbo to stock and now I have a high idle when warmed up it varies from 1500-2000rpm. I tested the IACV with a 6 volt battery and it clicks when voltage is applied. All of the vacum lines are hooked up I cant detect any leaks. I bypassed the FITV to see if that would help but no success. I replaced the intake mani gasket and used rtv to seal it, the throttle body gasket will also be replaced shortly. Could it possibly be caused by my injectors? I bought them used and the car doesnt turn over on the first try so Im thinking that maybe the spray is off or they cannot hold pressure, but would that cause crappy idle?
The car also redlines at 6800 for some reason. Vtec kicks in, but it redlines early. Im going to check the fuel pump, possibly get the injectors cleaned and also check the ignitor in the dizzy. I have a p72 ecu, but the guy that had it before me had it chipped by Dinan and its prittty old, possibly the casue of this whole crappy idle and early redline. O ya the wire that connects to the vtec solenoid is hard wired , I had to cut off the connector to wire in my old stanalone and lost the connector, could that cause the early redline?What do you guys think?? This is dragging on and I dont want to waste anymore money.
Old Apr 16, 2008 | 09:03 PM
Default Re: high idle, early redline WTF (aWeimaraner)
I checked injector resistance and came up with 11.5 ohms which is ok. I also checked injector plug voltage with key on and i got 12 volts also good. Im gona check the fuel pump and dizzy tomorrow night. Annyyyy suggestions??
Old Apr 16, 2008 | 11:35 PM
4DrFr3ak's Avatar
Did you ever thouch your throttle cable?
Old Apr 17, 2008 | 04:46 AM
Default Re: (4DrFr3ak)
Its not tight if thats what you mean. Its actually kinda lose, its a GSR cable on a b16a manifold.
Old Apr 17, 2008 | 09:08 PM
Still no luck, im gona swap in my buddies p72 ecu on monday to find out if its the ecu or not.
Old Apr 24, 2008 | 06:59 PM
ITR.#1446's Avatar
Default Re: (aWeimaraner)
hey i pm'd you just realized the ecu was obd2a so idk if you still want just send me a pm when you get this
Excusetoboost
Sep 1, 2011 07:40 PM
ejvtec
Jan 26, 2011 07:33 AM
vg_Ace
Nov 6, 2010 05:54 PM
zach1288
Jun 12, 2010 04:32 PM
95dc2teg
Sep 11, 2007 05:49 PM
