z6 in limp mode
Old Apr 14, 2008 | 05:58 PM
Japanese James's Avatar
Default z6 in limp mode
so i did a mini me swap and rushed the end of it by not getting my head resurfaced and used a cheap HG and reused headstuds being an idiot and i got that running and blew the rad by the time i got home. ran so good tho haha. cracked the block. bought a complete z6. low miles from an auto. swapped that in and starts right up but goes into limp mode. wont rev past 3200 but no CEL. iv been trying to figure it out for 3 months now. im about to give up and buy something else but i just lost my L for 3 months so i figure id still try to fix this. so pissed at it
Old Apr 15, 2008 | 12:23 AM
bryse68's Avatar
Default Re: z6 in limp mode (Japanese James)
check your wiring, check your distributor, both main causes for this problem, especially after converting to obd1
Old Apr 15, 2008 | 12:28 AM
ZCcivicBOI's Avatar
ive had this problem a few times most of the time it was because the two white wires on the dizzy plug were backwards. if you messed with the dizzy at all that might be the problem.
Old Apr 15, 2008 | 02:37 AM
zccr-xsi's Avatar
Default Re: (ZCcivicBOI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZCcivicBOI &raquo;</TD></TR><TR><TD CLASS="quote">ive had this problem a few times most of the time it was because the two white wires on the dizzy plug were backwards. if you messed with the dizzy at all that might be the problem.</TD></TR></TABLE>
yup thats more then likely the problem.i think tdc wire cps wire switch them around if itstill dont start then thers a problem
Modified by zccr-xsi at 7:08 AM 4/15/2008
Old Apr 15, 2008 | 06:44 PM
alright thanks. il go try that in a min.
Old Apr 16, 2008 | 05:47 PM
just tried switching the two white wires. turned over but didnt start.
Old Apr 16, 2008 | 06:24 PM
crxricer66's Avatar
Default Re: (Japanese James)
not 100% sure but dont the tps wires have to be swapped around?? or is that only with a dohc swap or sumthin. someone help with this. if so then maybe you didnt do that????
Old Apr 16, 2008 | 06:29 PM
yeah someone mentioned that on another forum. they said he had to switch the two wires on the TPS and it fixed it. i already tried that as well. still no luck
naterpatater77
May 8, 2009 11:11 AM
chickenwing
10
Sep 19, 2008 06:23 AM
9three4drintegra
Jan 17, 2006 11:35 AM
ek9800
Jun 20, 2005 11:11 PM
MENACE
Aug 1, 2004 04:35 PM
