WIRE REMOVAL!!!
Old Apr 14, 2008 | 04:30 PM
EFstyle's Avatar
Default WIRE REMOVAL!!!
I just took out my heater core, A/C box, and blower motor out from under the dash and im wondering about the black box that is mounted right behind the passenger side headlight... im pretty sure this is for A/C correct?? If so, What is the proper way of removing this ugly box and the wires running to it? thanks
Old Apr 14, 2008 | 04:51 PM
akandok's Avatar
pics?
Are you referring to the relays? Be careful because one of them controls your fans. I pulled mine completely but wired my fan to the ignition. When I turn my key to on it turns on..
Old Apr 14, 2008 | 05:20 PM
grog's Avatar
Default Re: WIRE REMOVAL!!! (EFstyle)
Here's a daigram of the ac system>>http://www.hondapartscheap.com...ch=no
not sure what black box you refer to, maybe the relays. When I removed mine I unplugged the cabin end of the wiring, and then removed the rest of the wiring by working my way to the front of the car. the AC harness is all by itself so removing it and its components is very easy. just make sure you only remove the wiring that goes to items you have removed (except for the one fuse box plug, remove it)
btw I always see post like "Im pulling my AC" and "I'm installing AC" these two groups need to get together and set up an exchange, like an "AC exchange" thread stickied
Old Apr 14, 2008 | 11:36 PM
EFstyle's Avatar
Default Re: WIRE REMOVAL!!! (grog)
im planning on hard wiring my fan anyways so thats not a problem... thanks for the info!!
Car_Retard
Jun 1, 2017 05:56 AM
Wazup
Sep 16, 2008 01:32 PM
grey_ghost
Sep 21, 2007 09:53 PM
The Hooligan
May 22, 2005 12:00 PM
HybridHatchC1
Apr 30, 2004 05:33 AM
