2007 civic si Coupe Fog lights HELP!!!!!!!
I am trying to find out some information on my fog lights! my car had came with fog lights and wanted to see if i can have the headlights off and the fog lights on my fog lights and not a button they are left side where you turn the lights on please help i want to have the fogs on without the headlights what can i do????????????
dude speak english. ok so first of all if i am hearing this right you want the fog lights on with out your head lights being on at the same time not having to use the switch that it came with. the problem is you are going to have to use some kind of switch to turn it on.
from civicforums.com
No need to get complicated. Hook them up like the OEM instructions say, but before wiring the switch up, just pick up an after market switch, a simple on off will do, and modify it to fit in one of the knock out switch panels. From here you have three prongs to connect wires.
1) power in
2) power out
3) ground
Fairly easy.
1) power in
2) power out
3) ground
Fairly easy.
