could this be the pressure plate
Old Apr 14, 2008 | 02:05 PM
deeweezy187's Avatar
Default could this be the pressure plate
Ok in the morning my clutch pedal needs time to build up pressure and after it sits for a few minutes its fine. My slave and master cylinders were just replaced. Could this be what is causing my car to rev high when i step on the gas once in a while.
Old Apr 14, 2008 | 07:55 PM
SOHCMAN's Avatar
Default Re: could this be the pressure plate (deeweezy187)
Anytime I hear " build up pressure" dealing with hydraulic systems, I believe it may have something to do with air in the system... Since the components were just replaced, there is a good chance of air in the system.
Have you bled the system since install?
When your car revs high when you get on the gas, it may be a slipping clutch...
sohc
Old Apr 14, 2008 | 08:53 PM
Default Re: could this be the pressure plate (SOHCMAN)
no not since the install but it did during it though.
Old Apr 15, 2008 | 11:44 AM
when the clutch is going out does the clutch pedal get stiffer to?
Old Apr 16, 2008 | 09:56 AM
SOHCMAN's Avatar
Not sure about the stiff clutch action, but I would go ahead and bleed the system really good and check your pedal adjustment to make sure nothing got boogered up when installing the new master cylinder...
sohc
Rickcrx
Transmission & Drivetrain
Apr 5, 2010 02:08 PM
Rickcrx
Mar 11, 2010 04:30 PM
boosted350z
Dec 5, 2004 06:07 PM
Nextelbuddy
12
Jul 14, 2003 11:34 PM
norice
Jul 31, 2002 03:53 PM
