Suspension & Brakes Theory, alignment, spring rates....
Koni Yellow Ground Control for CRX writeup?
Old Apr 14, 2008 | 01:26 PM
90JPRCRX's Avatar
Smells like Tuna
Default Koni Yellow Ground Control for CRX writeup?
The pictures in the FAQ at the top of the forum are down. Its not even for a EF CRX or with a coilover setup.
I need help. I can't find any writeups anywhere anymore. I'm looking for pre assembly write ups and/or installation write ups.
Should I put this perch clip on the bottom slot of the shock? Theres 2 on the rear and 3 on the front. Does that just determine ride height?
Theres a ton of little parts, washers, nuts, clips, bumpstops, etc... I can't find a clear writeup on the order these all go for a CRX. I have a brand new set of Koni Yellow & Ground Control coilovers, and they have all the instructions and everything, but they're not really clear.
Old Apr 15, 2008 | 07:09 PM
TOO MUCH TORQUE's Avatar
Default Re: Koni Yellow Ground Control for CRX writeup? (90JPRCRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90JPRCRX &raquo;</TD></TR><TR><TD CLASS="quote">The pictures in the FAQ at the top of the forum are down. Its not even for a EF CRX or with a coilover setup.
crx and integra share very similar suspension. refer to that thread for assembly.
for the clips, i left them on the center clip.
here i drew this picture on how all the pieces should be for a koni shock body
Modified by TOO MUCH TORQUE at 8:23 PM 4/15/2008
Captain Key!s
Suspension & Brakes
13
Nov 29, 2012 09:56 AM
CRXguy_88
19
Aug 14, 2011 08:10 AM
WhiteEG6
Feb 1, 2004 10:24 PM
88crxgsr
Jul 5, 2003 07:20 AM
x James Bond x
Jun 13, 2002 05:16 PM
