Climate Control *need assistance*
Old Apr 14, 2008 | 12:19 PM
AlphaQup's Avatar
Default Climate Control *need assistance*
Sup guys.
Recently picked up a DC and found out a minor issue with the climate control. Maybe someone here can help... The AC and heat works fine. The problem is that #1 & 2 selection modes do not work. Only 3 & 4 work. Any ideas?
Nick
Old Apr 14, 2008 | 12:59 PM
gurgle's Avatar
Default Re: Climate Control *need assistance* (AlphaQup)
There's a resistor pod mounted in the blower fan housing. There are 3 coils total in it.
The circuit for low speed (1) goes through all 3 coils.
The circuit for (2) goes through 2 coils.
The circuit for (3) goes through 1 coils.
The circuit for (4) goes through 0 coils.
Since 1 & 2 don't work, that means coil #2 is blown.
It's easily accessible. Take off the glove box, and you'll see wires going into a thingamajig which mounts on the blower housing. Remove and replace thingamajig ... ~$40 part at your Honda dealer IIRC.
Old Apr 14, 2008 | 01:12 PM
AlphaQup's Avatar
Default Re: Climate Control *need assistance* (gurgle)
Thanks man! I'll check it out today after work.
Old Feb 4, 2009 | 10:53 AM
Muad'Dib's Avatar
Corr Performance Pilot
Originally Posted by AlphaQup
Sup guys.
Nick
i also have the same problem but none of my selector switches work. the air comes through the front vents and not through the bottom or through the defrost vents. Any assitance with this would be greatly apprecaited.
Thanks!
Old Feb 4, 2009 | 10:55 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Sounds to me like there is an issue with the mode control motor, or the dampers, or the levers from the motor that control those dampers.
That's going to be difficult to diagnose without pulling the entire dashboard and heater box out.
Old Feb 4, 2009 | 10:57 AM
Muad'Dib's Avatar
yikes. how much work is involved in this? i've got the helms but need to know if this is gonna be a full weekend worth of work?
Old Feb 4, 2009 | 11:01 AM
Community Builder
If you can remove interior parts, it's not that big of a deal getting the dashboard out, especially if you have the Helms. Once you have everything out of the way, there's only 6 bolts that hold the dash on. It also helps to have 2 people to help maneuver the dash out of the car.
For me, the hardest part is getting the darn emerg. flasher and rear defrost switches out so I can remove the climate control module in order to get to the bolts behind there.
Old Feb 4, 2009 | 11:39 AM
Muad'Dib's Avatar
so basically i DO have to take the entire dash out to fix the air mixer motor?
Old Feb 4, 2009 | 01:32 PM
Community Builder
If that is the problem, then probably so. Even if it isn't, it will be 100x easier to diagnose with the dashboard removed.
Old Feb 5, 2009 | 11:22 AM
Muad'Dib's Avatar
well... its time to bust out that helms.
Old Jun 25, 2009 | 09:18 AM
Muad'Dib's Avatar
would this be what is faulty..... http://www.acuraautomotiveparts.org/...13st70_b17.gif
Old Jun 25, 2009 | 09:35 AM
Community Builder
Possibly, but more likely it is the mechanical parts on the heater box (mode control motor, dampers, and connecting links between each).
The Helms manual should have a process to troubleshoot the heater control unit with a multimeter. Then you can verify if it is working properly and move on to something else.
Old Jun 25, 2009 | 09:37 AM
Muad'Dib's Avatar
thanks patrick. one way or the other the helms always comes back to be the source for info.
tylergwesterhold
Jun 5, 2008 04:29 PM
kai-chun
Aug 29, 2006 09:38 PM
D-series ninja
Oct 5, 2005 10:50 PM
Hehehe I just
May 3, 2004 02:31 PM
