Gauge cluster!
my dx cluster went out the spedometer and the water temp doesnt work and it makes some clicking noise when the cars on i check the wiring and its fine i have an hf crx cluster how do you wire it up to my dx it has a tach mine doset?
what year is the cluster? if its a 88-89 cluster and your car is a 88-89 then its a straight plug and play deal, same with the 90-91 cluster if your car is a 90-91, other than that your S.O.L. the tach will work even though, your current cluster doesn't have it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by driftam1 »</TD></TR><TR><TD CLASS="quote">my dx cluster went out the spedometer and the water temp doesnt work and it makes some clicking noise when the cars on i check the wiring and its fine i have an hf crx cluster how do you wire it up to my dx it has a tach mine doset?</TD></TR></TABLE>
well its the blue wire coming off your 2 wire dizzy clip.and if u look at the cluster clip nearest to the driver side A piller.theres a soild blue wire on there thats your tach wire.
yea i have a tenzo r tach hooked up but all of a sudden wen i put my si trans in the speedomer dosent work and the water temp dosent work o well i ll figure it out if any 1 has advice let me know
Make sure your cable is all the way inside the trans. Did you ever disconnect the wiring to the temp sensor on the head?
I doubt the cluster would all of a sudden be "bad", Especially if you just removed the input from the 2 things that aren't working currently.
