89 crx HF H22 Shell cheap!! M2A4 JDM H22 trans, Spool, Diff, B18, Civic, Integra, CRX
*************SOLDDDDDD!!!!!!!!!***************
89 crx HF - Clean Title, Black Shell. (no motor, trans, Ecu,) <U>$1000 </U>Drop in an H22 motor and trans and go!!
car is setup for H22. Innovative H22 Mounts, Full Hydro pedal conversion not a cheap actuator, two sets of custom H22 Crx Axles, Wiring harness, OBD1 Jumper, relocated Battery, Place Racing Crossmember, coilovers, Kens Kustom chassis Brake master cylinder, steering wheel, etc... H22 shift linkage, Walbro Fuel pump, new suspension parts and fresh alignment, (new tie rods (ball joints)... etc... (slicks and rims not included, Motor/trans not included) will sell with black stockies....
Interior - Gutted dash (no heater or etc), two SI seats clean, carpet, door panels and functioning windows, no rear panels.
Carbon fiber hood. etc..
Also for sale JDM M2A4 transmission $500 - FULL time diff not LSD, Welded Diff, guaranteed traction!! Also included is a stock Diff if you want to go back to open diff.
Modified by h22crxpwr at 8:40 AM 7/16/2008
Modified by h22crxpwr at 3:05 PM 7/21/2008
Modified by h22crxpwr at 9:55 AM 7/28/2008
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FLATBUSH PROJECTS »</TD></TR><TR><TD CLASS="quote">????</TD></TR></TABLE>
going with EG chassis. Crx shell!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FLATBUSH PROJECTS »</TD></TR><TR><TD CLASS="quote">bump for you.... did you still need the crank and rods?</TD></TR></TABLE>
thanks. i gotta wait on the crank for a little bit trying to get some other parts together first.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fullyblown »</TD></TR><TR><TD CLASS="quote">bump for pics</TD></TR></TABLE>
laggin on pics. i'll try to take some today.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fullyblown »</TD></TR><TR><TD CLASS="quote">BUMP This Iam
i messd up and Sold it for Chep Mine
It Killed Evo and Sti All day long and whent heads up with a Gt2
well now you can buy my shell cheap and start over!! and its got a full hydro conversion, not sure if you had the actuator but this is WAY better. just like in an EG. all you need is an ECU, motor and trans!! comes with everything else!! i also have a trans for sale...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Golden Eagle »</TD></TR><TR><TD CLASS="quote">bump </TD></TR></TABLE>
thanks for the bumps. pics will be taken today.
how did you do the pedal assembly? what did you have to do to get this hydro setup to work. i'm looking to get rid of my cable setup, and i do not want to use the lame cable to hydro slave setups like they have now.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dem0nk1d »</TD></TR><TR><TD CLASS="quote">how did you do the pedal assembly? what did you have to do to get this hydro setup to work. i'm looking to get rid of my cable setup, and i do not want to use the lame cable to hydro slave setups like they have now.
lots of custom work. not the easiest thing to do and not much space in there to do it!!! pm me for details.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hionvtecxda6 »</TD></TR><TR><TD CLASS="quote">
thanks for the bump...
Pics finally added!!!
</TD></TR></TABLE>thanks for the bump...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IT’S ME DAVID »</TD></TR><TR><TD CLASS="quote">
thanks! TO the top!! someone buy this!! drop in a stock H22 and hit 12's!! or slightly built one and hit 11's!! Clean title in hand...
</TD></TR></TABLE>thanks! TO the top!! someone buy this!! drop in a stock H22 and hit 12's!! or slightly built one and hit 11's!! Clean title in hand...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22crxpwr »</TD></TR><TR><TD CLASS="quote">For Sale,
[/i]</TD></TR></TABLE> not bad come on someone buy it has lots of extras ready for h22
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Golden Eagle »</TD></TR><TR><TD CLASS="quote"> not bad come on someone buy it has lots of extras ready for h22
true!!! drop in your motor/trans and ecu and go!!! easy 12 second all motor car with stock H22.. also have an ACT clutch/flywheel setup for sale and a JDM H22 Trans for sale.. Also have H22 89 bore 12:1 Arias Pistons, and some other misc stuff for sale.
</TD></TR></TABLE>true!!! drop in your motor/trans and ecu and go!!! easy 12 second all motor car with stock H22.. also have an ACT clutch/flywheel setup for sale and a JDM H22 Trans for sale.. Also have H22 89 bore 12:1 Arias Pistons, and some other misc stuff for sale.
