How do you remove the front directional light Assembly?
Ok, I did a search for Honda forums.. Found this place. Actually found a few, but I hope there are more people who view the posts here, to get a faster response.
Bought a 1995 Honda accord about a week ago. So far I freakin love it. Has a few lighting changes done to it, nothing major.
How the hell do you remove the front directional marker lights?? Not in the bumber. I open the hood, remove the one screw, and you would think this puppy would just fall out...
Seems its getting caught on something on the bottom, like almost looks like a pin or some sort...
I put some serious presure on it, but it never came off.
Any help would be great.
wow, try posting a smaller picture or just post a link instead.
for the corner lights you should only have to remove 1 screw from up top and then disconnect two plugs and thats it.
there are the two little prong type things that are connected to the housing it should pull out though, dont pull up cause it will break them.
it is one screw and then pull foward a tad to get them out, you should have enough room so you can turn the lights and pull them out and there you go.
should take 5 mins max for both of them.
easy stuff!
easy stuff!
