S2K PRO-2 CAMSHAFTS
Old Apr 14, 2008 | 06:50 AM
EJ6SON's Avatar
Default S2K PRO-2 CAMSHAFTS
WOULD THOSE CAMSHAFTS WORK WITH A STOCK H22A (JDM) BOTTOM END, OR WILL I LOSE OUT BECAUSE OF THE STOCK COMPRESSION. I HAVE CAM GEARS SO I CAN DEGREE THEM IN BUT MY QUESTION IS THAT WILL I LOSE HORSEPOWER BECAUSE THE STOCK COMPRESSION
Old Apr 14, 2008 | 10:53 AM
EJ6SON's Avatar
Default Re: S2K PRO-2 CAMSHAFTS (EJ6SON)
? SOMEONE OUT THERE HAS TO HAVE THE PRO-2'S ON A STOCK H22A BOTTOM END. JUST A QUICK ANSWER
Old Apr 14, 2008 | 12:54 PM
EJ6SON's Avatar
WELL IS IT TRUE YOU NEED LOTS OF COMPRESSION FOR THESE CAMS TO WORK PROPERLY CAUSE IF SO I NEED TO SELL OR TRADE, I HAVE A STOCK BOTTOM END
Old Apr 14, 2008 | 01:49 PM
h22crxpwr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ6SON &raquo;</TD></TR><TR><TD CLASS="quote">WELL IS IT TRUE YOU NEED LOTS OF COMPRESSION FOR THESE CAMS TO WORK PROPERLY CAUSE IF SO I NEED TO SELL OR TRADE, I HAVE A STOCK BOTTOM END</TD></TR></TABLE>
TURN OFF YOUR CAPS LOCK...
okay now my personal experience with Pro 2's on stock JDM H22 is a loss of power. degreed in i have heard of them making great power on a stock JDM H22. cam gears set at 0,0 and we had a power loss on two separate motors. dyno'd 190.1 on stock cams, pro 2's dyno'd 180.
we did have good results with pro 1's. set at 0,0 they made 210 whp stock JDM H22.
Old Apr 14, 2008 | 06:48 PM
Combustion Contraption's Avatar
Default Re: S2K PRO-2 CAMSHAFTS (h22crxpwr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22crxpwr &raquo;</TD></TR><TR><TD CLASS="quote">okay now my personal experience with Pro 2's on stock JDM H22 is a loss of power. degreed in i have heard of them making great power on a stock JDM H22. cam gears set at 0,0 and we had a power loss on two separate motors. dyno'd 190.1 on stock cams, pro 2's dyno'd 180. </TD></TR></TABLE>
I havent touched a set of the H22 PRO2's, but I know with B series PRO2's, running at 0,0 will net you around .003-005" v2v clearance. Possible you bent some valves during tuning resulting in loss of power?
EJ6SON
44
Apr 16, 2008 04:13 AM
aznej2
14
Oct 9, 2006 04:04 PM
harlen
Mar 21, 2006 08:39 PM
StorminMatt
May 23, 2005 06:52 AM
acuraqc
Feb 16, 2004 08:15 PM
