AT radiator in MT 97 GSR
Old Jul 11, 2002 | 11:17 AM
HeelToe's Avatar
Default AT radiator in MT 97 GSR
I ordered a Radiator for a 97 GSR and got one with the fittings for the ATF coolant hoses, meaning I got a radiator for one of the AT Integras.
Looking at my old radiator, it appears to have the same mold for the lower tank, with "cut lines" where the manufacturer would cut the tank and mount fittings.
Can I remove the fittings and plug these holes and pretend like it's the correct radiator or will this result in a loss of coolant capacity as compared with the proper radiator for an MT Integra?
Everything else about the two radiators looks identical, and if I won't lose capacity, I'd prefer to not wait another 2 days for a replacement part and deal with returning this one.
Anyone know?
THANKS!
-matt
[Modified by HeelToe, 8:17 PM 7/11/2002]
Old Jul 11, 2002 | 11:51 AM
PaChiLa Leader's Avatar
Default Re: AT radiator in MT 97 GSR (HeelToe)
I do not know what's the differnce between AT and MT
but i did Auto to Manual conversion on my 2000 GS
and other than the tranny are auto... plus the radiator still functions..
hope that helps
Old Jul 11, 2002 | 04:47 PM
APEX i GSR's Avatar
the radiator will work fine a lot of aftermarket companies make one radiator for both manual & auto trans cars. obviously you won't hook up the trans cooler lines because you shouldn't have any. Radiator will perform normally
Old Jul 11, 2002 | 05:46 PM
HeelToe's Avatar
Default Re: AT radiator in MT 97 GSR (APEX i GSR)
Thanks for the help, guys. I'll go ahead and use it.
I have a question regarding the fittings fot the ATF reservoir. Should I remove the fittings and plug them? If so, how?
Thanks again.
-matt
Old Jul 11, 2002 | 07:55 PM
Brian_TII's Avatar
You don't need to bother plugging them. If you WANT to you can... but it won't hurt anything if you don't.
Old Jul 12, 2002 | 12:28 AM
brinks's Avatar
I just ran a legnth of coolant hose betwen the 2, secured it with hose clamps.
Old Jul 12, 2002 | 09:01 AM
HeelToe's Avatar
Default Re: AT radiator in MT 97 GSR (brinks)
Thanks for the help, guys. I plugged them with some hose caps from the auto parts store, reinstalled, and all seems well.
-matt
Old Jul 16, 2009 | 12:08 PM
k20ex's Avatar
I ran into the same issue when I purchased mine. Is it safe to just run a coolant line between the two coolant outlets and call it a day? Or do they need to be capped off? Thanks.
Old Jul 16, 2009 | 12:11 PM
ALLxMOTOR EG's Avatar
Vietnamese!
It's possible.
Old Jul 16, 2009 | 12:39 PM
tkda's Avatar
Originally Posted by ALLxMOTOR EG
It's possible.
that doesnt help.
not sure you even needed to plug them. i did auto to 5spd in an ef and just left the lines.
Old Jul 16, 2009 | 02:38 PM
ElementzofR's Avatar
i have a friend who ran his turbo's oil cooling lines to this same type of radiator. combined with the oil cooler that came with the turbo kit it actually works a lil better. just a little something to keep in mind if you ever plan on boosting.
Old Jul 17, 2009 | 06:42 PM
95LS1t's Avatar
you can just leave them, u dont need to plug them
i was running a halfsize civic radiatior that had the nipple thingys for the atf cooler on the bottom and my car is a 5spd, never leaked or anything like that
Soooogie
Oct 1, 2013 01:12 AM
djustice_tn
Aug 23, 2009 02:19 AM
escape2me
Apr 10, 2006 08:46 PM
SamC
May 18, 2005 05:51 PM
escape2me
Dec 3, 2004 02:51 AM
