Y8Intake Manifold on a Y7
Old Jul 11, 2002 | 10:54 AM
96hbdx's Avatar
Default Y8Intake Manifold on a Y7
I want to do the y8 manifold on a y7 swap . I can get a full intake manifold for cheap $. Will everything bolt right up and how will I go with getting the bottom bolts out
Old Jul 11, 2002 | 11:04 AM
EVIL Hx Coupe's Avatar
Default Re: Y8Intake Manifold on a Y7 (96hbdx)
Everything will bolt right up.
Old Jul 11, 2002 | 11:43 AM
BARF1's Avatar
Default Re: Y8Intake Manifold on a Y7 (Boost Pressure)
http://www.makuragi.s5.com/civic_99/Y8maniswap/
Old Jul 11, 2002 | 12:50 PM
brcivic411's Avatar
you mean the bottom center bolt? i was actually able to bust it loose from ontop of the car (the side actually with an extension and wobbly joint). the tighten it back up, i HAD to do it from underneath the car.
remove the manifold brace (if you even have one) before getting to that bolt
Old Jul 11, 2002 | 08:01 PM
WFRcougar's Avatar
Default Re: Y8Intake Manifold on a Y7 (brcivic411)
Also, will the fuel rail and injectors from the Y7 bolt to the new manifold (havent looked at the new one yet and was planning on doing this myself). If not, what all do I need to make it work?
daknightfall
Jun 22, 2010 06:39 PM
GiMpInThaCiv
Oct 31, 2006 01:58 PM
Stu
Jan 15, 2004 01:19 PM
JDMlyfestyle
Jun 2, 2003 01:19 AM
