aem cold intake when carwash
ey guys
im planning on carwashing sometime this week since the weather is too good to just stay in my room
but when i pour water would that cause water to go into my aem cold air intake??
i thought since my car is not turned on it would be okay but one of my friend says that i gotta be careful withthat...
so whatdoya guys say?
I wash my car every friday, and I have a Fujita cold air intake. Hell, I've even autocrossed in the rain countless times. (STANDING WATER)
As long as you don't put the intake tube in a bucket of water you should be fine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkankyEJ7 »</TD></TR><TR><TD CLASS="quote">As long as you don't put the intake tube in a bucket of water you should be fine.</TD></TR></TABLE>
Well I need to stop that. Guess my car should use a straw next time....
If the cars not running you have nothing to worry about. Rain won't be a problem either. If the filter get's submerged while the car is running it will hydrolock when the water travels throught the throttle body and into the engine. If you're worried about puddles you can also put the clutch in while going through deeper water and coast for a little after that to keep the engine safe.
u should be ok less chance of water getting in it if it has no flat level spots in the tubing like the s2000, friend took off the aem that came on his S and found lots of water in the bottem half of the intake
