Where do you relocate your battery in your race/street car
im thinking bout doing a T1 oil catch can but unsure where to relocate my battery does anyone have pictures of slick ways they mounted theres in there dc or any honda in that manner
Just a note for anyone looking to relocate the battery and wanting oem reliability, the OEM Miata battery works great and is a little shorter and a little wider than a civic battery. Sometimes it works out better than a civic battery.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 »</TD></TR><TR><TD CLASS="quote">Just a note for anyone looking to relocate the battery and wanting oem reliability, the OEM Miata battery works great and is a little shorter and a little wider than a civic battery. Sometimes it works out better than a civic battery.</TD></TR></TABLE>Good to know...
what are the cca on the miata battery? I am considering moving my battery from the rear to back under the hood. I think you lose so much current thru the long runs of wire.
Your power wire wont effect your cranking amps unless it is too small.
I personally like the battery in the front wheel well as apposed to the trunk. Now this is probably because im more into racing than sterio systems and the front would provide more weight over the front wheels for better traction.
I like to put the battery behind the right headlight. Makes it easy to get to if you need to charge it or remove if. Doesn't work with abs though.
Does anyone make a kit or the brackets to mount behind the bumper like the ones posted above?
If u put i'n the back truck make sure u get a kill switch and a approved battery box or
Track will bitch I just got a moroso Black box or blue
I was gonna put i'n from wheel well but my piping i'n the way look kinda dangerous to me
DC2*Integra
Oct 16, 2005 06:33 AM
