DOHC ZC into my 91 hatchback
I've run SOHC for way too long and now I want HP...can anyone tell me from 1-10 how hard it'd be to swap a DOHC ZC into my car? Its Dual Point injection which I really liked. PLEASE HELP
you are not going to notice much difference between your sohc and a dohc zc. Save us all some time and effort and take a look at the faqs at the top of the page all your questions should be answered
i hate smart asses like that guy. anyways...a PM7 ecu and what about wiring harnesses? remember Im not running multi-point but DUAL POINT.
here, save ur self the time and frustration, this is the best way to go http://cgi.ebay.com/ebaymotors...ZWDVW he also makes the small harness needed to run the dohc zc, that way u dont have to do any major wiring.
i used this on my buddies car that he got with someones sorry a$$ attempt at using a 92-95 harness wired upto the dx main harness. this guys work is great, one part is confusing, just read the instructions carefully, i felt like a tard once i realized i wasnt reading it right, ull know what part it is when ur reading them. it doesnt get any easier than this harness
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91BluMaxHatch »</TD></TR><TR><TD CLASS="quote">i hate smart asses like that guy. anyways...a PM7 ecu and what about wiring harnesses? remember Im not running multi-point but DUAL POINT. </TD></TR></TABLE>
your calling me a smart *** when all the information to do this swap is located in our faqs section maybe if you would have used that before posting you could have saved us all a little bit of life. But at least you found your wiring harness on here which also could have been found with a little bit of searching.
hold on your going to run dpfi on a mpfi engine.. first you need to swap out the dpfi for mpfi then you can get a pm7 ecu or a pm6 to run it.. or you can chip the pm6 . to install the dohc zc into a 91 hb it's easy as hell.. besides the wiring that you would have to do to. stock mounts work for it. but if you want hp then you need mpfi.
SIred91
30
Aug 17, 2006 07:35 PM
zeptozorro
Jan 18, 2004 09:01 PM
