Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Redline problem
Old Apr 13, 2008 | 04:39 PM
riptosredek's Avatar
Default Redline problem
I recently bought a 2008 honda civic si. The redline has always kicked in at 8000 rpms, but now it hesitates at 7000-7500 rpms, and almost seems to bounce off the rev-limiter at 7500 rpms... The check engine light isn't on, and everything else seems normal with the car. My car doesn't even have 3000 miles on it yet... wtf is the problem????
Old Apr 13, 2008 | 04:45 PM
TheMuffinMan's Avatar
He knows where you live!
I guess break in periods don't really exist anymore.
Old Apr 13, 2008 | 04:52 PM
Default Re: (TheMuffinMan)
they already come from the factory with a break in...
Old Apr 13, 2008 | 05:06 PM
Manual says 1000 miles + no vtakkk
I don't own an SI so I can't compare your redline problem to my LX haha.
Old Apr 13, 2008 | 06:05 PM
lilced03's Avatar
sounds like your pushing it to hard. any new motor needs to be broken in.
Modified by lilced03 at 12:42 PM 4/14/2008
Old Apr 13, 2008 | 06:11 PM
RICO_'s Avatar
NO MERCY!
Default Re: (riptosredek)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by riptosredek &raquo;</TD></TR><TR><TD CLASS="quote">they already come from the factory with a break in... </TD></TR></TABLE>
No sir they do not.
They come with a special Honda break in oil....but the engines themselves are NOT broken in. You need to wait the specified number of miles before becoming aggressive with the car.
What octane gas are you using?
Old Apr 13, 2008 | 06:25 PM
Default Re: (RICO_)
i did the break in process
i've always only put 93 octane in the car
Old Apr 13, 2008 | 06:33 PM
autoxmyef's Avatar
If the engine isnt warmed up it ecu has a second rev limited around 7500rpm or so till the engine is up to temp.
Old Apr 13, 2008 | 11:32 PM
lostjap89's Avatar
Default Re: (autoxmyef)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by autoxmyef &raquo;</TD></TR><TR><TD CLASS="quote">If the engine isnt warmed up it ecu has a second rev limited around 7500rpm or so till the engine is up to temp.</TD></TR></TABLE>
yep had it happen to me i forgot it wasn't all the way warmed up and tryed to get around some trafic and it hit at 7500ish
Old Apr 14, 2008 | 09:40 AM
100miles+'s Avatar
From: In Diamond Bar, CA Brake Boosting like a Mother Focker!
Default Re: (lostjap89)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lostjap89 &raquo;</TD></TR><TR><TD CLASS="quote">
yep had it happen to me i forgot it wasn't all the way warmed up and tryed to get around some trafic and it hit at 7500ish </TD></TR></TABLE>
Old Apr 14, 2008 | 11:37 AM
lostjap89's Avatar
Default Re: (100miles+)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 100miles+ &raquo;</TD></TR><TR><TD CLASS="quote">
yep i deserve it
Old Apr 14, 2008 | 06:30 PM
thanks so much problem solved
haha oops... this is when i wish i was blonde so i have an excuse
ets_2007civic
12
Dec 20, 2006 03:23 AM
westspeed
Nov 21, 2006 09:39 AM
gofastant
Aug 12, 2004 03:56 PM
hondacivic_si
Jul 10, 2004 12:01 PM
