Identify these wires.
Old Apr 13, 2008 | 04:01 PM
suno's Avatar
Default Identify these wires.
This is my shifter console, and the cigarette lighter and ash tray light don't work.
I can't find a harness for this plug so I was thinking of just running wires from the fuse box, ground, etc.
There are 4 wires:
Black
Red
Red w. black stripe
White w. Blue stripe
Obviously the solid black one is ground, and there must be a constant and switched power. But what would be the white one? Some kind of switch right?
Any help would be great, I finally want to get this done.
Modified by suno at 5:07 PM 4/13/2008
Old Apr 13, 2008 | 06:48 PM
silverAC's Avatar
Default Re: Identify these wires. (suno)
i wouldn't assume that black is ground but i can see from the pic that it is. follow the wires. where do they go? Typically a honda uses red/black as illumination voltage and white/blue is constant voltage(it definately is if it leads to the center of the bak of the lighter socket). Might be able to tell you the other wire if i knew where it went.
Old Apr 13, 2008 | 06:50 PM
silverAC's Avatar
Default Re: Identify these wires. (silverAC)
sorry, lighters in hondas are switched so the white/blue would be switched if it leads to the lighter socket.
Old Apr 13, 2008 | 07:42 PM
suno's Avatar
Tried taking a picture but turns out shitty.
This is how it goes.
Black: Goes to the metal tab seen on the bottom right of the first pic. Then splits ...goes to the back of ash tray bulb.
White/blue: Back of cigarette lighter
Red: back of lighter bulb
Rad/Black: Splits into 2 and goes behind both light bulbs.
Looks to me like the white/blue is the dimmer switch. Black is ground.
Old Apr 14, 2008 | 06:01 PM
silverAC's Avatar
Default Re: (suno)
black=ground
red/blk=illumination
red=dimmer
Old Apr 14, 2008 | 06:02 PM
silverAC's Avatar
Default Re: (silverAC)
wht/blu=switched power
jsmith1107
Nov 19, 2014 08:12 AM
Jeager521
Audio / Security / Video
Oct 20, 2002 10:49 AM
TONEBONE
Aug 18, 2002 03:07 PM
lodown414
Jun 19, 2002 09:44 PM
Iggy_Type_R
May 14, 2002 08:41 AM
