ignition wiring help! pic
Im wondering what the thing you screw to the bottom of the ignition is. it goes right under the key hole kind of. It is a little black plastic thing that has the little White/Blue and Blue/White wires going into it.
Also what is the wire on the right side for starter? The left is the battery terminal correct?
Modified by s5rx7 at 5:23 PM 4/13/2008
Modified by s5rx7 at 7:21 AM 4/14/2008
I know 100% the Black with White wire, after it plugs into the fuse box is the wire that supplies your starter with power when you turn the key to start.
Also on the picture, one wire is battery as you have labeled and the other side goes to the positive terminal on the starter, the other end of that wire has a ring connector on it and it hooks to the post terminal on the starter.
The others I am not sure on.
The one with the question mark you have it goes to the alternator on top. Should be a white wire.
The others I need pictures then I can tell you, or you can just get the fsm and look at the electrical and find out.
I got the ignition all taken care of except that piece that has two little wires running to it and it screws onto the ignition . Now im just wondering what all goes in that slot on the fuse box because nothin is hooked up there.
Most likely a jumper for another vehicle and they just use the same box for several vehicles. So youll see plugs all over the car that are not connected, simply becuase whatever car they use the same plug in gets used just not on yours
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by s5rx7 »</TD></TR><TR><TD CLASS="quote">I got the ignition all taken care of except that piece that has two little wires running to it and it screws onto the ignition . Now im just wondering what all goes in that slot on the fuse box because nothin is hooked up there.</TD></TR></TABLE>
That little black box does tie into the ignition switch, it should all just come together at the large 4 prong connector that goes into the Fuse box.
No the one with the question mark is just a single wire, that runs directly to the alternator. The battery one goes like this. Main fuse box-battery post-starter.
The alternator wire just runs straight though. To the fuse box.
Alright i went to the junk yard and got the alternator wire and the hot wire. Now on the starter their is a post that the wire from the fusebox+ batt. screws to and theirs another wire that plugs into the start right next to the post. Its a black with white stripe wire what does that lead to?
b16_madman
12
Jul 28, 2004 05:39 PM
