Urgent help, please - Engine won't turn to set TDC
Old Apr 13, 2008 | 01:42 PM
braass91's Avatar
Default Urgent help, please - Engine won't turn to set TDC
91 civic DX 1.5 - Timing belt replacement
I tried to set the TDC several times and passed the mark and now, the engine won't turn to set the TDC. Did I turn it too many times? How can I set the TDC mark now?
Thanks
Old Apr 13, 2008 | 01:53 PM
zrickety's Avatar
Default Re: Urgent help, please - Engine won't turn to set TDC (braass91)
the crankshaft is not turning at all? is the camshaft turning? you need to be careful setting everything to TDC. did you encounter some hard resistance the last time it turned? you may have bent something. what are you turning it with?
Old Apr 13, 2008 | 02:02 PM
braass91's Avatar
Default Re: Urgent help, please - Engine won't turn to set TDC (zrickety)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zrickety &raquo;</TD></TR><TR><TD CLASS="quote">the crankshaft is not turning at all? is the camshaft turning? you need to be careful setting everything to TDC. did you encounter some hard resistance the last time it turned? you may have bent something. what are you turning it with?</TD></TR></TABLE>
The crankshaft pulley is turning, but the camshaft pulley with the 'UP' mark is not turning at all to where I can set TDC to the mark. Using socket set.
Old Apr 17, 2008 | 09:43 PM
mouab18c1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by braass91 &raquo;</TD></TR><TR><TD CLASS="quote">
The crankshaft pulley is turning, but the camshaft pulley with the 'UP' mark is not turning at all to where I can set TDC to the mark. Using socket set. </TD></TR></TABLE>
set the crank pulley to tdc and then set ur cams to where they should be....align the white marks next to each other...the up arrows are just references...the white marks on ur cams determine where they need to be set
pre-posterous
Apr 19, 2014 02:57 AM
EK FLY
Oct 11, 2011 04:47 PM
BryanPendleton
13
Jun 22, 2006 08:38 AM
biggdogg
Aug 30, 2002 05:27 PM
