NEED SOME HELP!!! H22a with chipped P06 ecu would this work.
Old Apr 13, 2008 | 09:13 AM
96plusf20bb's Avatar
Default NEED SOME HELP!!! H22a with chipped P06 ecu would this work.
I got an 92-96 h22a auto motor and wanted to used a P06 chipped ecu with a
94-97 ex accord tranny. would this work if i got a flywheel, clutch etc..
going in a 97 ex civic that already had an f20b with a obd2 to obd1 convertion harness running in it..
or would i need more stuff to do the swap.
also is the auto h22a motor have less HP/TQ than a h22 manual
thanks everyone, found some stuff in the search but not enough to anwser my question.
Modified by 96plusf20bb at 10:24 AM 4/13/2008
Modified by 96plusf20bb at 6:32 PM 4/15/2008
Old Apr 13, 2008 | 09:29 AM
ludecz's Avatar
Default Re: NEED SOME HELP!!! H22a with chipped P06 ecu would this work. (96plusf20bb)
JDM h22a has .6 more compression then USDM h22a1/4, so a little more power and torque. If the chip inside that ecu holds map for Accord like f22 it should make the h22a running, but you will need to tune it ASAP.
Old Apr 13, 2008 | 11:54 AM
Default Re: NEED SOME HELP!!! H22a with chipped P06 ecu would this work. (ludecz)
So, in other words the ecu will control the motor but it will have to be tune.
and what about the auto to manual convertion is easy right i do have to get the clutch and the flywheel and assemble and call it the day.
Old Apr 15, 2008 | 06:19 AM
TylerC161's Avatar
i ran with a p06 for a while back when i got my car. as said youll NEED a tune, or at LEAST get someone to burn a basemap on the chip for you. the p06 and p28 are really similar, IIRC someone said a p06 could pretty much become a p28 with a few solders
Sungsu
Apr 14, 2010 04:06 PM
tkhang
Mar 11, 2010 06:08 AM
95accordexb
May 2, 2007 05:07 AM
Acclude
Sep 11, 2002 08:39 PM
