Picture of JDM DC 4-1 on ef ground clearance
Old Jul 11, 2002 | 09:23 AM
sparkz's Avatar
Default Picture of JDM DC 4-1 on ef ground clearance
Here is a picture detailing the ground clearance on my EF with the JDM DC 4-1 headers. I have a B-series motor with the ha sport mounts. It hangs really low, about 3 inches below the cross member. Look at the box of cigs for reference
Old Jul 11, 2002 | 09:25 AM
89 CRX SI's Avatar
Default Re: Picture of JDM DC 4-1 on ef ground clearance (sparkz)
damn
what out for like a penny on the road
that would suck to bend them the have like2 sylenders cut out and not notice JK
Old Jul 11, 2002 | 09:47 AM
RyanR's Avatar
My was about the same height if not a little lower. After 2 months the bottom 2 tubes were smashed in half. I put the stock header on and it flowed better.
Old Jul 11, 2002 | 10:02 AM
johnzm's Avatar
Default Re: Picture of JDM DC 4-1 on ef ground clearance (RyanR)
why dont u guys weld a skidplate onto the primaries?????? it cannt be that expensive
Old Jul 11, 2002 | 10:05 AM
SuperCivic's Avatar
dayam gina!!! did you have to cut your front crossmember at all to install? did it mate to the cat like the stock one did? and how bout the o2s? sorry for all the questions .
Old Jul 11, 2002 | 10:11 AM
sparkz's Avatar
Default Re: Picture of JDM DC 4-1 on ef ground clearance (SuperCivic)
yes the crossmember had ot be notched slightly but it was pretty easy. not sure if its my car or how the hasport mounts sit but the headers angle up towards the car so i had custom piping to get it straightened out. as for o2's, i only needed 1 since i converted to obd1.
RyanR's Avatar
Yes, the crossmember has to be cut/smashed in. The O2 had to be relocated right before the collector and you'll have to have a different cat flanged welded on. I'd suggest getting a 2.5" high flow cat to replace the stock cat.
Old Jul 11, 2002 | 10:29 AM
SuperCivic's Avatar
kewl..i already had a custom exhaust made for my stock b16 header with catco cat. noticable gains over stock?
Old Jul 11, 2002 | 10:43 AM
Reid's Avatar
Global Moderator
Default Re: Picture of JDM DC 4-1 on ef ground clearance (johnzm)
Someone from HYBRID was making them.
I forgot the link since I don't use a JDM 4-1, but they are out there.
Old Jul 11, 2002 | 11:08 AM
drunken jdm monkey's Avatar
Default Re: Picture of JDM DC 4-1 on ef ground clearance (Reid)
ya mine jdm dc 4-1 hang about that low.B16a with motor mounts made by the crower integra driver.I had a small skid plate welded an so far so good.I am plannin to sell this header for a jdm itr to get alittle more clearance.
Old Jul 11, 2002 | 11:16 AM
Eggman's Avatar
eww, only homos smoke menthols? j/k. nice header. i heard from others that the hasport mounts point the header up, due to the new design (raised rear of motor for ground clearance). which is weird cuz the front of the header still hangs the same. but supposedly hasport is gonna redesign it again. it not just you, although mine dosent seem to do that. i need to look at it closer though.
your car gonna be ready for this weekend?
Chas
Old Jul 11, 2002 | 11:21 AM
02WRX's Avatar
Default Re: Picture of JDM DC 4-1 on ef ground clearance (Eggman)
Yep, I got the same issue. Running the DC 4-1 99 Si headers. Even though I've been really careful & my car's not totally dumped, I smacked em once already. I think I'll change to the 4-2-1 1pc design for better front crossmember & ground clearance.
Eric
Old Jul 11, 2002 | 12:02 PM
customx_'s Avatar
New User
skidpads here
http://fastlineperformance.com/products.htm
Old Jul 11, 2002 | 01:22 PM
n2o914drb16's Avatar
Default Re: Picture of JDM DC 4-1 on ef ground clearance (mindtrix)
damn how lows your car cause mines dumped bout 4-5inches
Old Jul 11, 2002 | 04:14 PM
mannyman's Avatar
El Veterano de Sur Califas
cool, thanx for the link. And does the jdm itr really give more clearence??? I thought the dc was an exact copy of the jdm itr. And i am digging those skidplates.....nice!! I was going to purchase a dc, but now i am having second thoughts. Does anyone actually have the plates, and have some good things to say about it??????
manny
Old Jul 11, 2002 | 04:24 PM
Ham'ed Hatch
Guest
Posts: n/a
Default Re: Picture of JDM DC 4-1 on ef ground clearance (n2o914drb16)
yeah sure buddy.
let's see some pics of this 5" dumpage...
Old Jul 11, 2002 | 07:11 PM
DohcVtecEF's Avatar
From: Sactown soon to be Layton, CA soon to be UT, USA
Default Re: Picture of JDM DC 4-1 on ef ground clearance (two.oh)
aye will those skid plates work on a ef hatch casue those are hella dope and i need to get one before i dent mine up any more...
Old Jul 11, 2002 | 07:21 PM
Default Re: Picture of JDM DC 4-1 on ef ground clearance (DohcVtecEF)
i don't have any pics but it was just a guesstamation at about how low it is....it's prolly closer to 4.....i'm running neuspeed race springs with 2 coils cut, on a 91 4dr...i had a set of ground control coilovers that made it sit about 1.5-2 inches higher,and aren't those things supposed to drop ya about 3"....thats why the guess of 4-5"
Old Jul 11, 2002 | 09:50 PM
sparkz's Avatar
my car isnt even that low, probbaly have a finger gap between tires and fenderwell.
Old Jul 11, 2002 | 10:22 PM
redteg1's Avatar
those marlboros are 100s
Old Jul 11, 2002 | 11:54 PM
philly-O's Avatar
Default Re: Picture of JDM DC 4-1 on ef ground clearance (redteg1)
i just bought a 4-1 header for my 89 hatch and you guys are making me worried now because my car is dropped 2.5" with tenzo springs. and i had problems hitting stuff without the header.
Old Jul 12, 2002 | 01:25 AM
sparkz's Avatar
haha those arent 100's but it kinda does look like it from an angle
Old Jul 12, 2002 | 05:34 AM
ricodemus's Avatar
you guys think those skidplates will work with the DC header for the 99-00 si? Mine is getting scraped up too, and I would like to stop it before any more damage is incurred. I'm using the HASport mounts too. The 99-00 si header bolted right up to the cat, but I guess it's nowhere near as good as the jdm one?
Old Jul 12, 2002 | 05:41 AM
REX VT's Avatar
I showed this picture before..
Fixed aluminium tie bar.. Saved my header (engine too)
Old Jul 12, 2002 | 06:11 AM
Denny317's Avatar
That link says that the skidpads will ONLY work for JDM Type R headers...no other brand names such as DC, Mugen, etc etc will work. Is that true?
