crx si rear disc on a crx dx
Old Apr 12, 2008 | 07:09 PM
jayden1295's Avatar
Default crx si rear disc on a crx dx
hi everyone me and a couple of friends went to the junk yard today and supprisingly i found a crx si and it had the rear disc still on it... so we took off the rear disc, ebrake cable and stuff that was attach to it. i was wondering if i can just put it on my crx dx or do i need anything else, like the master cylinder. any help would be nice thanks H-T...
Old Apr 12, 2008 | 07:31 PM
pandarex's Avatar
Default Re: crx si rear disc on a crx dx (jayden1295)
you really should use all the si master cylinder and proportioning valve. you can put the brakes on without out em but youll probably have soft brakes
Old Apr 12, 2008 | 08:00 PM
jayden1295's Avatar
Default Re: crx si rear disc on a crx dx (pandarex)
where is the proportioning valve located... thanx
Old Apr 12, 2008 | 08:13 PM
jayden1295's Avatar
by the way is that all i need....
Old Apr 12, 2008 | 08:32 PM
pandarex's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jayden1295 &raquo;</TD></TR><TR><TD CLASS="quote">where is the proportioning valve located... thanx
under the fuse box, with all the brake lines going into it. also if you can get the brake booster off the donor car. if you have the whole rear end than thats all you need
Old Apr 12, 2008 | 08:33 PM
89GSRHATCH's Avatar
all you need is the si ppv the dx master cylinder is the same as the si master cylinder you can use the si ppv but the brakes wont feel as good the ppv is right under the fuse box in the engine bay you will see all the brake lines going into it hope this helps
Old Apr 12, 2008 | 08:34 PM
89GSRHATCH's Avatar
Default Re: crx si rear disc on a crx dx (89GSRHATCH)
i ment to say u can use the dx ppv but the brakes wont feel as good sorry for the type-o
Old Apr 12, 2008 | 08:42 PM
jayden1295's Avatar
thanks everyone...
Old Apr 12, 2008 | 08:57 PM
jayden1295's Avatar
one more question. if i had a rear disc conversion from an integra will my hx rims still fit my car with out a problem thanx..
Old Apr 12, 2008 | 09:20 PM
pandarex's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jayden1295 &raquo;</TD></TR><TR><TD CLASS="quote">one more question. if i had a rear disc conversion from an integra will my hx rims still fit my car with out a problem thanx..</TD></TR></TABLE>
its the da front that dont clear the hx rims. the rear is fine
sbarmann
Mar 15, 2009 02:15 AM
crxfreak1117
Sep 29, 2006 03:27 PM
teler86
Suspension & Brakes
Feb 15, 2006 11:08 AM
crxhftosi
Jan 30, 2005 10:13 PM
Davanca
11
Mar 15, 2004 12:27 PM
